By default EnergyPlus mirrors shading surfaces at runtime. That may be important for vertical fins, but if your shading surfaces are horizontal then you can turn this off. It might also be nice to see an image of the model to see why there are so many surfaces.
You might also look at your timestep in general too see if it can be relaxed, and also see what solar distribution you need for your model.
