The short answer is no. At least the ScheduleRuleset object that makes most of our schedules doesn't support holidays, and there isn't a way in OpenStudio store holidays. Eventually we need two things.
What can you do today? I see two options if you want to include holidays, neither one is very pretty:
Mimicking holidays with ScheduleRuleset.
Using Compact Schedules
Import compact schedules into your model. Ideally they will be edited as needed ahead of time since you can't edit them in the OpenStudio application, alhtough if you had ot you can edit them in the SketchUp Plugin.
You need to tell EnergyPlus what holidays are. There are two options. Option "A" is to set the "Use Weather File Holidays and Special Days" field of the OS:RunPeriod object to yes. You would need to do this in an OpenStudio measure since the GUI doesn't expose this field. Option "B" is to write an EnergyPlus to manually add the specific holidays you want instead of relying on the weather file.
Warning: If you enable holidays and you also still use some ScheduleRuleset objects in your model there might be un-expected consequences, so I wouldn't recommend a hybrid of these two solutions.
Import compact schedules into your model. Ideally they will be edited as needed ahead of time since you can't edit them in the OpenStudio application, alhtough although if you had ot to you can edit them in the SketchUp Plugin.
Mimicking holidays with ScheduleRuleset.ScheduleRuleset
Import compact schedules into your model. Ideally they will be edited as needed ahead of time since you can't edit them in the OpenStudio application, although if you had to you can edit them in the SketchUp Plugin.
Warning: If you enable holidays and you also still use some ScheduleRuleset objects in your model there might be un-expected consequences, so I wouldn't recommend a hybrid of these two solutions.I seem to recall that the default profile was being used where a holiday was defined.
| 4 | No.4 Revision |
UPDATE OpenStudio Application 1.1.0 October 2020
The OpenStudio Application now supports Holiday profiles similar to how summer and winter design days are setup https://github.com/openstudiocoalition/OpenStudioApplication/pull/60
There is a new simulation setting to use the weather file for holidays. If you want to define custom holiday dates you can alter the weather file or can write a measure using RunPeriodControlSpecialDays
| 5 | No.5 Revision |
