Technically I think you would want the convective heat transfer from the zone surfaces, not the conductive heat transfer.
Technically I think you would want the convective heat transfer from the zone surfaces, not the conductive heat transfer.transfer. Convection is what contributes to the zone air heat balance, conduction is through the envelope and affects the surface inside face temperature (which is used in the convection calculation).
