|   | 1 |  initial version  |
This is just a ScheduleConstant object. It has a single value all the time. It is made at times through the API, but isn't something you can inspect or alter in the GUI. It is the same as if you made a Ruleset Schedule with only the default profile and set it to always equal 1.
Here is what the object looks like. It is typically used for availability schedules.
OS:Schedule:Constant,
{966ffa9b-9939-4499-a950-d82bd2f10042}, !- Handle
Always On Discrete, !- Name
{07123e75-72aa-4cb6-b376-38f41b9624e3}, !- Schedule Type Limits Name
1; !- Value
