There was a bug in the openstudio-standards gem where running the measure in the app broken the relative path to weather file directory for weather files included with openstudio-standards. It is fixed, and will be in the next openstudio-standards release out at the end of this month (Oct 2024).
If you want to use it in the current version of the app, you'll need to update your gems to use the latest version of openstudio-standards. Here are instructions to loading custom gems.
There was a bug in the openstudio-standards gem where running the measure in the app broken broke the relative path to weather file directory for weather files included with openstudio-standards. It is fixed, and will be in the next openstudio-standards release out at the end of this month (Oct 2024).
