click to hide/show revision 1
initial version
After several testings, I think the problem is still related to HVAC system sizing. Since this model comes with a default WSHP system. In order to fully cap the system capacity, I need to specify the values for the following parameters:
  1. Gross_Rated_Total_Cooling_Capacity
  2. Gross_Rated_Sensible_Cooling_Capacity
  3. Rated_Air_Flow_Rate
  4. Rated_Water_Flow_Rate
  5. Fan:Maximum_Flow_Rate
Those are my two cents...
