You can attach multiple HVAC equipment (whether zonal equipment, airloop HVAC, etc.) to the ZoneHVAC:EquipmentList object. This object defines all HVAC equipment serving the zone.
To specify the operation, you could then:
(Alternatively, you could probably set the Sequential Heating/Cooling Fraction Schedules to constant 1s, and then use availability schedules on the equipment themselves to define their operation.)
