Hi, can you check the IDF file and make sure it contains this object as described in the docs:
OutputControl:Table:Style, CommaAndHTML; !- Column Separator
The warning about not having report variables is only relevant when you start running the project in jEPlus+EA. It doesn't matter if you only need jEPlus.
