You may also try jEPlus and jEPlus+EA (https://jeplus.org) to do perform parametric analysis and optimisation on the IDF models created by DesignBuilder. jEPlus tools can extract values that you can see in eplustbl.htm. It requires some understanding of the IDF file structure, but it is not too hard especially if you don't need to manipulate geometries.
