This type of error is generated when dereferencing an unset optional or a bad pointer, so it is usually the result of a bug in OpenStudio. So sending the file to the OpenStudio team helps us find and fix this bug (in addition to getting you unstuck on your work). If you are able to, please send this file to OpenStudio@nrel.gov. We will create an issue and look into it for you.
