EnergyPlus is giving an error as follows: * Severe ** <root>[WaterUse:Equipment][Level0:Bedroom Water Outlet] - Missing required property 'peak_flow_rate'.
when the numerical value of the peak flow rate value is replaced by an arithmetic operation using the built-in macro #eval[ ].
For example when #eval[0.0000067517*1 ] is input instead of 0.0000067517 for the peak flow rate, the severe error is output.
Is only a numerical value accepted for this input not a macro?
