I know it's confusing, but you must install the OpenStudio Application, not the OpenStudio SDK.
Re-read the wiki at: https://github.com/openstudiocoalition/openstudio-sketchup-plugin/wiki/OpenStudio-SketchUp-Plug-in-Wiki
Get the 1.6.0 from https://github.com/openstudiocoalition/OpenStudioApplication/releases/tag/v1.6.0.
The OpenStudio Application 1.6.1 will also include internally the OpenStudio SDK 3.6.1, so no need to install it separately. The OpenStudio Application has special ruby bindings that the OpenStudio SDK does not have, and that the openstudio-sketchup-plugin needs to work.
Point the OpenStudio Root Directory to C:\openstudioapplication-1.6.0 once you have installed the OpenStudio Application 1.6.0.
The OpenStudio Application 1.6.1 will also include internally the OpenStudio SDK 3.6.1, so no need to install it separately. The OpenStudio Application has - in addition to the Graphical User Inferface - special ruby bindings that the OpenStudio SDK does not have, and that the openstudio-sketchup-plugin needs to work.
