FYI, I'm adding such diagnostics to OpenStudio in PR#4843 so soon you'll have native methods to detect and fix incorrectly oriented surfaces. You can try one of the installers linked in the comments if you want.
Otherwise, in sketchup, look at your Thermal Zone 1, and check which faces are dimmer/lighter color than the others, that'll tell you you're looking at the other side. You can then select it, right click, and "Reverse/Flip vertices" (terminology might not be exact, I don't have sketchup on this Ubuntu machine)
Otherwise, in sketchup, look at your Thermal Zone 1, and check which faces are dimmer/lighter color than the others, that'll tell you you're looking at the other side. You can In SketchUp: Double click the space to enter the space group, then select it, the face, right click, click and "Reverse/Flip vertices" (terminology might not be exact, I don't have sketchup on this Ubuntu machine)select 'Reverse Faces' (thanks @Eric Ringold)
