That is great to hear as this is a needed feature for labs where zones are negatively pressurized and receive make-up air from other zones. I could see this living at the zone level in the GUI as it will most often be used in conjunction with the Zone Exhaust Fan object which is currently access at the zone level as well.
That is great to hear as this is a needed feature for labs where zones are negatively pressurized and receive make-up air from other zones. I could see this living at the zone level in the GUI as it I will most often be used in conjunction with the Zone Exhaust Fan object which is currently access at the zone level as well.
That is great to hear as this is a needed feature for labs where zones are negatively pressurized and receive make-up air from other zones. I could see this living at the zone level in the GUI as I will most often be used use this in conjunction with the Zone Exhaust Fan object which is currently access at the zone level as well.object.
