As I mentioned in the comments, I performed a similar analysis with variable transmittance schedule and noticed the same issue, so I posted this question. Within the question, I referred to 2 GitHub posts on the same issue but I am not sure if the issue is resolved!
One work around that I can think of is to avoid using EMS since, it seems, is not working properly with transmittance schedules.
Schedule:File object
to easily import your schedule from a
.CSV file.So Basically, the idea is to use the transmittance schedule directly considering the control logic rather than relying on EMS to do the job!
